Volvo
( Volvo C70 & S70 & V70 ) kod bledu 261A 91A7
   Forum VOLVO Forum Strona Główna -> ( Volvo C70 & S70 & V70 ) Silnik iskrowy -układ chłodzenia-układ zasilania-układ napędowy oraz wydechowy.
rozekbstok
Posiadane auto: v70
Wysłany: Wto 25 Sty 2011, 18:41
kod bledu 261A 91A7
witam posiadam volvo v70 t5 rok 2000 wyskoczyl mi taki blad 261A 91A7 na przepustnicy co to moze byc
spokoluzik
Skąd jesteś (miejscowość / region): zamosc/lublin/london
Posiadane auto: XC90 3.2 Petrol, C30 Rdesign
Piwa: 31/6
Wysłany: Wto 25 Sty 2011, 19:35
Re: ( Volvo C70 & S70 & V70 ) kod bledu 261A 91A7
284: ECM-261A Long-term fuel trim. Lower limit, B5234T7
Print
Diagnostic trouble code (DTC) information
Condition
The control module receives information from the heated oxygen sensor (HO2S) about the fuel / air mixture when idling at both the lower and upper part-load range. If the fuel / air mixture deviates from λ=1, the short-term fuel trim will compensate for this by adjusting the injection time so that λ=1 is achieved. When the short-term fuel trim makes an adjustment, the integrator median must be adjusted by the long-term trim. Diagnostic trouble code (DTC) ECM-261A will be stored when the long-term trim must be adjusted to almost maximum in the lower part load area.
Substitute value
none
Possible source
Upper limit:
intake air leakage
exhaust system air leakage
low fuel pressure
defective heated oxygen sensor (HO2S)
Lower limit:
intake air leakage
high fuel pressure
leaking injectors
defective mass air flow (MAF) sensor
contaminated engine oil
oil level too high
284: ECM-91A7 Throttle position (TP). Faulty control, B5234T7
Print
Diagnostic trouble code (DTC) informationECM-91A7
Condition
Turbo engines and 6-cyl non-turbo engines
If Electronic throttle module (ETM) registers a too high difference between desired value and current value in the internal regulator or a too high current passes through the electronic throttle module's torque motor, then this information is sent to Engine control module (ECM), which then stores diagnostic trouble code ECM-91A7, Faulty control.
5-cyl. non-turbo engines
If Electronic throttle module (ETM) registers a too high difference between desired value and current value in the internal regulator, a too high current passes through the electronic throttle module's torque motor, or that the throttle disc does not move despite a control signal to the motor, then this information is sent to Engine control module (ECM), which then stores diagnostic trouble code ECM-91A7, Faulty control.
For more information about the electronic throttle system and related components such as the electronic throttle module, accelerator pedal position sensor, brake light switch, clutch pedal position sensor, and brake pedal position sensor: Design Function
Substitute value
Fuel cut-off that follows accelerator pedal position.
Engine speed is regulated via fuel cut-off by deactivating the injectors one at a time. Engine speed is determined by gas pedal position sensor position and engine speed is maximized to about 5000 rpm. This reconfiguration can cause the engine to idle very unevenly since the engine control module (ECM) regulates engine speed by cutting of the fuel to the cylinders individually. Do not confuse this reconfiguration (engine behavior) with an actual driveability problem that was present before reconfiguration.
Closing of throttle during braking.
The accelerator pedal position is ignored when the brake pedal is depressed.
Cruise control off.
Cruise control off during entire operating cycle in which fault was detected. If the fault is no longer present, the function is available the next time the car is started.
Throttle switched off (only 5-cylinder aspiration engines).
The electronic throttle module (ETC) deactivates the throttle motor control, which means that the throttle is not actuated and assumes its mechanical stop position. This means about 20% throttle opening. This reconfiguration is always followed by fuel cut-off.
For upgraded software, released in 2006 or later, adjustments have been made to substitute values. In driving cycles when the fault is active, fuel shut-off that follows the accelerator pedal position will be activated.
Identifying upgraded software ECM/ETM
Possible source
something is blocking the throttle position sensor (an oil film, dust etc.)
poorly charged battery or corroded in the connecting cables
the power supply to the throttle unit
defective throttle unit.
This diagnostic trouble code is generated in combination with other trouble codes. Information on the possible root cause is described.
Information about combined diagnostic trouble codes (DTCs)
Fault symptom[s]
the accelerator pedal (AP) is ignored when braking
the cruise control cannot be activated
uneven idle
jerks during engine braking
very poor throttle response (only 5 cylinder engines with DENSO electronics)
maximum speed approximately 50 km/h (only 5 cylinder engines with DENSO electronics)
the ETS warning lamp lights (C70 and S/V70 -2000 only).
volvo vida diagnostic-caly Londyn
http://volvodiagnostic.com
rozekbstok
Posiadane auto: v70
Wysłany: Wto 25 Sty 2011, 20:59
dziekuje lecz gdyby pan moglby mi to na polski przetlumaczyc byloby super <piwo>
marek746
Posiadane auto: volvo xc90
Piwa: 5/2
Wysłany: Wto 25 Sty 2011, 21:59
kolego troszke inicjatywy tu masz link zaznacz skopiuj i wklej w tłumacza tu masz link Smile http://translate.google.pl/#
spokoluzik
Piwa: 31/6
Wysłany: Wto 25 Sty 2011, 22:49
jakby bylo dwa zdania to bym ci tego nie wklejal ale jakos mi sie nie widzi tej litanii tlumaczyc. mysle ze uzycie translatora to tobre rozwiazanie...
rozekbstok
Posiadane auto: v70
Wysłany: Sro 26 Sty 2011, 09:28
dzieki <piwko>
   Forum VOLVO Forum Strona Główna -> ( Volvo C70 & S70 & V70 ) Silnik iskrowy -układ chłodzenia-układ zasilania-układ napędowy oraz wydechowy. Wszystkie czasy w strefie EET (Europa)
Popularne dyskusje w dziale: ( Volvo C70 & S70 & V70 ) Silnik iskrowy -układ chłodzenia-układ zasilania-układ napędowy oraz wydechowy.
VolvoV50
15 900
226 000 km
VolvoInny
94 900
229 000 km
świętokrzyskie
VolvoV40
66 900
147 815 km
VolvoXC 90
144 900
161 220 km
VolvoXC 40
94 500
158 921 km
