Volvo
( Volvo S60 ) volvo s60 anti-skid
   Forum VOLVO Forum Strona Główna -> ( Volvo S60 ) Elektronika/Elektryka/Komunikaty.
ko13
Skąd jesteś (miejscowość / region): MIELEC
Posiadane auto: VOLVO S60 2,4 D5 2004
Wysłany: Sro 26 Sty 2011, 18:09
volvo s60 anti-skid
witam wszystkich
posiadam volvo S60 2.4 D 2004
mam problem z anti skid
to sa kody 040092-040109-040021-040031
prosze o podpowiedz
Ostatnio zmieniony przez ko13 dnia Sro 26 Sty 2011, 22:47, w całości zmieniany 1 raz
spokoluzik
Skąd jesteś (miejscowość / region): zamosc/lublin/london
Posiadane auto: XC90 3.2 Petrol, C30 Rdesign
Piwa: 31/6
Wysłany: Sro 26 Sty 2011, 20:34
Re: ( Volvo S60 ) volvo s60 anti-skid
popraw kolego posta i nie uzywaj caps locka
wtedy ci podpowiem
volvo vida diagnostic-caly Londyn
http://volvodiagnostic.com
spokoluzik
Piwa: 31/6
Wysłany: Sro 26 Sty 2011, 23:05
593: BCM-0092 Yaw rate sensor. Faulty signal
Print
Diagnostic trouble code (DTC) information
Condition
Note! The diagnostic trouble code (DTC) applies only to cars with dynamic stability and traction control (DSTC).
The yaw rate sensor, lateral accelerometer, accelerometer and angle of lean sensor (only RSC) are integrated in the active yaw control sensor for DSTC (dynamic stability and traction control). The sensors transmit information to the brake control module (BCM) indicating the size of the yaw angle, the lateral acceleration of the car, the forward acceleration and the lateral angle of lean via the Control area network (CAN).
Diagnostic trouble code (DTC) BCM-0090, BCM-0091, BCM-0092 or BCM-0093 is stored, depending on the sensor, if the control module registers a faulty signal from any of the sensors.
BCM-0090: Lateral accelerometer
BCM-0091: Accelerometer
BCM-0092: Yaw rate sensor
BCM-0093: Angle of lean sensor.
The diagnostic trouble code (DTC) can be diagnosed while the ignition is switched on.
Substitute value
Traction control is blocked
Stability control is blocked
Active yaw control is blocked
RSC system is blocked (cars equipped with RSC only).
Hint:
For information about brake system abbreviations, see Brake system, abbreviations .
Possible source
Open-circuit or short-circuit to ground in the wiring for the active yaw control sensor
Internal fault in the active yaw control sensor.
Note! This diagnostic trouble code (DTC) is not due to an internal hardware fault in the Brake control module (BCM) and must not be remedied by replacing the control module.
Fault symptom[s]
The anti-spin warning lamp is lit (up to and including 2002 model year)
General yellow warning lamp lit (from model year 2003)
Anti-spin does not function
The stability control system does not function
The traction control system does not function.
593: BCM-0109 Communication between control modules. Communication with the steering angle sensor. Internal fault
Print
Condition
The control module for the steering angle sensor transmits a status signal to the brake control module (BCM).
Diagnostic trouble code (DTC) BCM-0109 is stored if the brake control module (BCM) receives a message from the steering angle sensor indicating an internal fault.
Substitute value
Active yaw control is blocked.
Hint:
For information about abbreviations, see Brake system, abbreviations .
Possible source
Internal fault in the control module for the steering wheel angle sensor.
Fault symptom[s]
General yellow warning lamp lit (from model year 2003 inclusive)
dwa nastepne to bledy czujnikow abs
jak podrzucisz wiecej informacji o tym co ci sie wyswietla bedzie latwiej okreslic co sie dzieje. rozumiem ze nie pali ci sie kontrolka od abs??
ko13
Wysłany: Czw 27 Sty 2011, 12:16
Dziękuję za te informacje. Jeśli chodzi o ABS to się nie świeci, jedyna informacja to "anty-skid". Po podpięciu do komputera są te błędy o których pisałem, wszystkie mogę wykasować oprócz jednego 040092.
spokoluzik
Piwa: 31/6
Wysłany: Czw 27 Sty 2011, 23:06
rozumiem ze po przejechaniu kilku kilometrow wszystkie bledy powracaja??
jesli tak to napisz czy komunikat o anty skid sie wyswietla odrazu czy po przejechaniu kilku metrow.
ko13
Wysłany: Pią 28 Sty 2011, 17:14
komunikat o anty skid wyswietla sie odrazu a blad 040092 nie da sie skasowac pozostale bledy zapalaja sie po paru kilometrach
Nismo73
Posiadane auto: S60
Wysłany: Nie 06 Mar 2011, 22:35
odp
a Panowie wiedzą, że komunikat o ANTI SKID pojawia się w Volvo, gdy np. akumulator daje słabe napięcie??? Wink... sprawdźcie... podładujcie akumulator, a komunikat w wielu przypadkach sam zniknie
bazabuz
Skąd jesteś (miejscowość / region): tychy
Posiadane auto: Mercedes B160 2010r. Automat
Wysłany: Sro 20 Lut 2013, 23:20
s60 anti skid
odgrzewam kotleta.
u mnie pojawilo sie abs nie chce zgasnac. i jak rusze to po 5 metrach zapala sie komunikat w kompie abs/ant skid ... serwis.
jaka jest roznica przy zapalaniu sie od razu anti skid czy zaraz po ruszaniu czy jak zaswici sie podczas jazdy i podczas jej wylaczy sie????
jutro na kompa ide to cos sie dowiem. oby to [cenzura] byla:)
bazabuz
Wysłany: Sro 20 Lut 2013, 23:23
anti skid
a wracajac do kodu ...92 lub poprzedzajacy lub kolejne ...9. to mam rozumiec ze wadliwy modul abs. tak?
spokoluzik Very Happy
Kamil199510
Skąd jesteś (miejscowość / region): Mińsk Mazowiecki
Posiadane auto: Volvo S60 2.4d 2006
Wysłany: Wto 02 Sty 2018, 19:07
Anti-skid
Witam. Kontrolka od trakcji wyskakiwała mi przy każdym odpalaniu samochodu i świeciła prawie caly czas czasami zgasła ale po przejechaniu kilkunastu km powracała. Pierwsze co pojechałem pod kompresor i dobiłam w każdym kole 2.6 bara (zalecane) w każdym kole i było to samo. Po oponach widziałem ze jest zbyt mało powietrza opony 205.55.16 i dopompowalem na 3bary bynajmniej na przodzie i kontrolka zgadła. Pozdrawiam.
wiktorclunk
Skąd jesteś (miejscowość / region): Piastów
Posiadane auto: S60 2.4 170KM beznyna+LPG
Wysłany: Sro 19 Gru 2018, 12:37
Anti-skid
Witam wszystkich
Mam Volvo S60 2.4 170 KM 2004
Pojawił się problem z anti skid
Akumulator sprawdzałem jest dobrze naładowany.
Komunikat pojawia się po pierwszym hamowaniu. Podczas hamowania czuć przerywanie na pedale hamulca.
Następnie ABS nie działa bo podczas mocnego hamowania koła się blokują.
Proszę o podpowiedz co robić.
Czy to sprawa dla mechanika czy elektryka ?
   Forum VOLVO Forum Strona Główna -> ( Volvo S60 ) Elektronika/Elektryka/Komunikaty. Wszystkie czasy w strefie EET (Europa)
Popularne dyskusje w dziale: ( Volvo S60 ) Elektronika/Elektryka/Komunikaty.
VolvoXC 60
170 000
2022r.
31 000 km
VolvoXC 60
143 800
130 000 km
VolvoV50
15 900
226 000 km
VolvoS80
25 900
297 298 km
VolvoV40
79 900
143 110 km
